#1 tacho on ca ?
oan878 Posted on: 2006/8/31 12:10
Hi where do u wire in a tacho on a ca18det in a 1200?
i have a standard ecu and loom.
the tacho said to wire the green wire in to coil or signal.
please help.
thanks Chris.
#2 Re: tacho on ca ?
dattodude Posted on: 2006/8/31 12:27
12v feed to the coils. This wire sees the 4 pulses which is enough to make the tacho work. It is polarised, so make sure you wire it in the correct way.
#3 Re: tacho on ca ?
oan878 Posted on: 2006/8/31 12:32
do u know what colour the wire is?
#4 Re: tacho on ca ?
dattodude Posted on: 2006/8/31 12:52
No I don't mess with factory looms much these days
It's the wire that connects to the centre conductor on the 3 pin plugs to each of the coils.
It splits into 4 wires at the engine bay. Might have been red with a white trace..that's completely from memory though.
#5 Re: tacho on ca ?
oan878 Posted on: 2006/8/31 13:19
Thanks i will work it out from here.
