#1 L series in 1200 ute
crzy_1200_ute Posted on: 2006/10/17 6:08
Hey guys
wondering how much work it is to get a L series into a datto ute?
and wat is involed? wat needs changing?
cheers
#2 Re: L series in 1200 ute
DemonFreeman Posted on: 2006/10/17 6:16
#3 Re: L series in 1200 ute
sikdatto1200 Posted on: 2006/10/19 10:34
basics that i did for taller l20b, scallop out crossmember, new mounts, grind off g/box mounts, custom g/box mounts, space swaybar to clear oil pump, arrange hydraulic clutch, tailshaft, cut out radiator support, used camry radiator, exhaust etc etc. Relitivelly easy but time consuming to get right! Go for it im sure people can help you out with any problems!
#4 Re: L series in 1200 ute
tom210 Posted on: 2006/10/19 10:36
what type of camry?
#5 Re: L series in 1200 ute
PIGDOG Posted on: 2006/10/19 11:00
89 model, try to get an aftermarket one as they are twin core and copper, not single and alloy with plastic tanks like the stock ones
its about as side as you can go in the front of a 1200, i had to dint the bottom tank slightyly to clear the bumper nut on the body, aftermarket one is slightly wider than the standard camry one
#6 Re: L series in 1200 ute
shirley Posted on: 2006/10/19 12:17
What about the radiator that came with the L20. Will it fit?
#7 Re: L series in 1200 ute
WhiteSedan Posted on: 2006/10/19 12:20
I know my stanza one was too high, i coulnt even close the bonnet, also look into new commo rads, there is heaps that fit. I used the saab one cause i got it for cheap and got it recored.
#8 Re: L series in 1200 ute
sikdatto1200 Posted on: 2006/10/19 13:25
yea from front wheel drive 88 89 model camrys, i found bluebird radiator to be too tall, with thermos mine hasnt past 80degrees so far with turbol20b
#9 Re: L series in 1200 ute
tom210 Posted on: 2006/10/19 13:28
arrk sweet, so they're fine for l series.. i wonder how one would go in a 120y. as in dimensions
#10 Re: L series in 1200 ute
mad120y Posted on: 2006/10/19 23:31
Got a camry one in melb, free if anyone wants it... I went series 2 vn in the end for mine, cos i had issues with sr20 alt getting in the way!
