#1 shaving ute vents
dat5_al Posted on: 2006/10/23 13:21
hey guys,
i have cancer covering one of my vents, i will have to cut it out so can you shave the vents off so its just flat. ive seen it done but wat are the consqeunces of it.
patts
#2 Re: shaving ute vents
WhiteSedan Posted on: 2006/10/23 13:23
Your cab wont vent properly if you do this, my mate did it with a 1600, couldnt stop the rear window from fogging up. Plus its one of those mods that is hard to reverse, keep the vents dude.
#3 Re: shaving ute vents
dat5_al Posted on: 2006/10/23 13:38
how hard is to get rid of rust with keepin it. does anyone kno of a ute were i can cut out this side vent
#4 Re: shaving ute vents
WhiteSedan Posted on: 2006/10/23 13:44
A good panel beater should be able to make up the section to go in there matey, go to someone that knows how to do proper metal work, theres people out there who can copy panels from a sample so doing what you want is pretty easy.
#5 Re: shaving ute vents
dat5_al Posted on: 2006/10/23 13:50
anyone can suggest someone for rust removal.
#6 Re: shaving ute vents
dattodevil Posted on: 2006/10/23 19:36
The vents also join up to inside the body, you can move the vents by venting the tray sides underneath the vehicle.
#7 Re: shaving ute vents
TnPshow Posted on: 2006/10/24 3:19
SA Chassis are good for rust removal I've heard and quite reasonably priced too (haven't tried them myself though).
They're on South Road near the intersection of Richmond road.
#8 Re: shaving ute vents
dat5_al Posted on: 2006/10/24 3:54
if i vented it under the tray wouldnt that rust hell easy. wat if i just removed the venta altogether would it only casue my rear window to fog cause i always always have my window down
#9 Re: shaving ute vents
phat_dat1200 Posted on: 2006/10/24 7:23
the vents have been shaved off my ute and i dont get any problems at all
#10 Re: shaving ute vents
dat5_al Posted on: 2006/10/24 7:26
sweet well guess the vents are gonna be shaved
