#1 CA18 turbo camshafts into NA motor
BUNDY351 Posted on: 2006/12/6 18:50
Hay all, Just did a search on ebay and found a set of HKS cams for CA18DET. 264 degrees and 9mm lift. Anyone out there know how these cams would respond in a NA motor. Could I also get the cams Ground to suil my needs.
#2 Re: CA18 turbo camshafts into NA motor
matbighat Posted on: 2006/12/7 0:14
increased lift & duration? should be good
#3 Re: CA18 turbo camshafts into NA motor
BUNDY351 Posted on: 2006/12/7 6:19
I just always presumed that Turbo spec cam shafts had and exhaust grind that opened the valve earlier and kept it open longer. Keeping it open longer may not be a bad thing especially for NOS.
#4 Re: CA18 turbo camshafts into NA motor
UTE18L Posted on: 2006/12/7 7:22
Use CA16 cams, do a search and there will be some info
#5 Re: CA18 turbo camshafts into NA motor
BigV Posted on: 2006/12/7 7:39
before you spend big dollars on jap cams
give someone like wade cams a ring they do SR cams so they may be able to help you
www.wadecams.com/
#6 Re: CA18 turbo camshafts into NA motor
datsik Posted on: 2006/12/9 7:53
"I just always presumed that Turbo spec cam shafts had and exhaust grind that opened the valve earlier and kept it open longer."
I believe the opposite to be true???? Due to positive pressure in a turbo cylinder..if the exhaust was open longer, it would mean more overlap with the intake...thus..you would be dumping plenty of fresh air straight out of the exhaust???
#7 Re: CA18 turbo camshafts into NA motor
B210sleeper Posted on: 2006/12/9 7:54
don't turbo cams have less overlap? which is not helpful to a NA engine, because it won't be able to use the exhaust suction to pull in a fresh charge?
I thought that was primarily what made a turbo cam different?
#8 Re: CA18 turbo camshafts into NA motor
datsik Posted on: 2006/12/9 8:06
"don't turbo cams have less overlap? which is not helpful to a NA engine, because it won't be able to use the exhaust suction to pull in a fresh charge?"
exactly....so if the exhaust duration was longer, (this is what Bundy351 is saying) then the intake duration would be less...(if overlap in a turbo motor is less than on N/A motor).
So basically...turbo cams no good for N/A motors!!!
#9 Re: CA18 turbo camshafts into NA motor
B210sleeper Posted on: 2006/12/9 9:22
makes sense to me. and a NA cam in a turbo probably results in fire coming out the exhaust a bit more.
#10 Re: CA18 turbo camshafts into NA motor
Daveman Posted on: 2006/12/9 12:09
As far as I know, the CA18DE cams are the same as the DET ones. This would probably mean that those cams would be an upgrade for either form of the motor. On turbo motors, increased overlap can still be beneficial, it just might push the peak torque point further up in the rev range, but will make more peak power.
