Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
120y diff
dats-me
Posted on: 2006/12/19 11:18
what diff is in my 120y? its a late model 4 door sedan, 1976. is it a H145 or H155? do H165's only come out of utes?
#2
Re: 120y diff
sikdatto1200
Posted on: 2006/12/19 12:08
id guess H150 for the aussie 120y, they say borgwarner on the bottom of housing, they have a rear cover
#3
Re: 120y diff
PIGDOG
Posted on: 2006/12/20 6:22
it will be a BW if it has a removable cover at the back of the diff
and either a h150 or h145 if it doesnt
#4
Re: 120y diff
shirley
Posted on: 2006/12/21 1:31
So if its a removable cover bw. What size does that make it?
#5
Re: 120y diff
mad120y
Posted on: 2006/12/21 2:17
BW68
They are pretty strong - ment to be stronger than h165
#7
Re: 120y diff
mad120y
Posted on: 2006/12/21 4:12
There will be a metal tag on one of the bolts that holds the cover on. I believe it tells you which type of borg warner, and also the ratio (makes life easy at the wreckers).
I recently put a bw68 from a corolla in my 1200 for the better ratio and wider track :)
#8
Re: 120y diff
PIGDOG
Posted on: 2006/12/21 4:50
was looking at a corolla diff just before, loks to be the same size as coronna and 200b BW diffs
#9
Re: 120y diff
Posted on: 2006/12/21 6:49
See Rear Axle Swap
There are pictures there: Quote: 120Y 4-dr sedans and wagons were Australian assembled and had a Borg Warner diff (BW model 68). All were 3.89 ratio, although the 120Y wagon and panelvan might have had a different ratio.
#10
Re: 120y diff
WhiteSedan
Posted on: 2006/12/21 7:11
You say the BW KE?? corolla diff is a bolt in, will this bolt up to the BW 1200 tailshaft?
Also I measured my mates Ke30 Wagon, centre of leaf to centre of leaf and it was 10-15mm wider than a 1200. I was thinking the mounting lugs on the leafs are larger in diameter on a corolla and this should allow it to fit anyway. Can anyone verify this? EDIT, I just read to wookie and it says that you need the 120y BW diff flange and 120y tailshaft, guess i can use the 1200 BW flange! You can view topic.
