Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
SEDAN WINDSCREEN WIPERS
slimpickaus
Posted on: 2001/3/12 9:36
The deluge that we had in Brisbane last week highlighted the inadequacy of the standard 1200 sedan wipers. They wipe too slow even on the higher of the two speeds. Has anybody done
an upgrade to a motor combination that wipes faster? Barry
#2
dattodude
Posted on: 2001/3/12 11:00
I haven't.
Would also be interested in an upgrade possibility. Chris
#3
Re: SEDAN WINDSCREEN WIPERS
val_and_datto_dude
Posted on: 2001/3/14 4:41
nope, me neither....
but, i have a question. What causes the windscreen wipers to sratch the windscreen? Coz i have a scratch that follow the exact path of the wipers on my windscreen. It's a pretty deep gouge as well, but it's only happened on the drivers side. What causes this? and how do i stop it? just keep it clean? thanks -Jesse
#4
teretonga
Posted on: 2001/3/14 5:18
The wiper blade wore out or was damaged and the arm began to contact the glass. Eventually the previous owner (relation?) figured it out and replaced the insert but the
damage was done. Either that or your Mum scratched it deliberately because you keep on doing burnouts in her driveway.
#5
chris_lott_nz
Posted on: 2001/3/15 12:33
ha ha ha ha man you crack me up teretonga.
his mum didnt scratch it she told me the other night... nah... anyways the scratch will go away if you take you bonnet off and drive around with the oil fill cap off. yeah about the wiper speed problem, get a torch or else take out the dash, get a torch anyways and take a look at the pivots for the wiper mechinisimimimim or however you spell it, anyways put some light oil or whatever on these pivits as it is most probably 30 years since it was last done, also pull out the multi plug going into the motor its self and spray with a contact cleaner to clean it up a bit, this will speed the wipers up, and if your really keen get some silicon blade inserts as they slide a bit better than normal ones. but yeah, even before i did this (the dash was out anyways) the wipers were more than all good with the only hassle being that they dont actually touch the screen at 90 m/h+ but i got over it.
#6
dattodude
Posted on: 2001/3/15 3:04
I also find driving at over 100mph in the rain that the wipers just can't keep up the job. Is this a shortcoming of the car..or of my common sense as to what is a good speed
to be travelling in the rain...hmmm Chris
#7
fester2au
Posted on: 2001/3/15 5:26
Obviously you guys don't have big enough balls as opposed to wiper motors because you shouldn't need to turn the wipers on at that speed the water should be self disbursing. Alcohol.
metho and water make a good cleaner that also helps to let the water bead off without wipers (at certain speeds and rain volumes). I run it in the washer bottle as well and find the water beads off as well as on a well polished paint finish.
#8
val_and_datto_dude
Posted on: 2001/3/16 8:00
teretonga you knobhead =)
my mum doesnt give a shit if i do burnouts (she calls them 'wheelies', hehe), as long as i dont break anything, and i clean the rubber off the driveway. Just washed my sisters sunny today....did you know that on her car her rocker cover has 'Nissan' written on it, but on my 1200 sedan i have 'Datsun' written on it........weird....
#9
chris_lott_nz
Posted on: 2001/3/18 3:32
if you want man i can hook you up with a rocker cover that has DATSUN on it for her car... or a cover with nissan on it for your car. i also am developing a water spray device that
sprays a mixture of Alcohol/Water to allow the water to bead off the rocker cover at high speeds as my balls are so big that i dont need to fit wipers to my rocker covers. suck on that. not my big balls... i ment the idea... sweet! glad thats cleared up.
#10
mareospeedwagon
Posted on: 2001/3/18 11:06
Keep a good coat of wax on your windshield and the water will bead off at slow speeds. Rain-
X works well also. You can view topic.
