#1 Clutch Hydraulic Line in the US?
NMUFO Posted on: 2007/2/9 16:55
I've called a few of my local shops and they all say it's NLA. Does anyone know a part # that would work for this purpose?
THANKS IN ADVANCE!!
Rich (walking eveywhere now)
#2 Re: Clutch Hydraulic Line in the US?
Gary_P Posted on: 2007/2/9 17:20
The hoses from the later cars should fit. In fact, a lot of the brake hoses from cars with a solid rear axel will work also.
When I put the 60 series 5 speed in the formerly auto 1200, the B310 hose was too short to reach the clutch slave. I used the rear brake hose from an early 510 wagon.
Sounds like a trip to U-Pull-It is in order.
#3 Re: Clutch Hydraulic Line in the US?
B210sleeper Posted on: 2007/2/9 19:18
you can use a piece of stainless flex brake line for the clutch too ;)
it's nothing special.
or just buy a rear brake line from a 210. not get a 30 year old one. nobody changes them unless they burst.
#4 Re: Clutch Hydraulic Line in the US?
Duncan Posted on: 2007/2/10 4:59
Check your yellow pages for hydraulic hoses. Almost any shop should be able to make one up for you.
There is a white 1200 Couple on ebay right now, and the fellow selling it owns a hydraulic line shop here in So Cal. I'm sure he could do one for you, also.
#5 Re: Clutch Hydraulic Line in the US?
Dodgeman Posted on: 2007/2/10 13:08
Duncan is on the right track. Any respectable brake specialist organisation should be able to make a replacement as per your sample.
The Hot Rod blokes get this stuff made up all the time.
#6 Re: Clutch Hydraulic Line in the US?
ang94541 Posted on: 2007/2/10 15:19
I believe it's the same hose as the rear brakes.
#7 Re: Clutch Hydraulic Line in the US?
B210sleeper Posted on: 2007/2/10 15:49
i bet they are still available - www.partsamerica.com...
#8 Re: Clutch Hydraulic Line in the US?
ang94541 Posted on: 2007/2/11 5:44
Try
Beck/Arnley 073-0879
#9 Re: Clutch Hydraulic Line in the US?
NMUFO Posted on: 2007/2/11 8:46
Thanks for all the help Gang!!!
The part I used is "BRAKEWARE 77001" it was $12 at Autozone and it was in stock! It's about 1.5-2 inches longer then the original, does not hang to low and bolts right up, NOW if I can get it all to work now! I've bought a rebuilt Master and Slave but I still have no pressure... GRRRRR I have a feeling the rebuilt MC is bad...
AGAIN THANKS!!
#10 Re: Clutch Hydraulic Line in the US?
Dodgeman Posted on: 2007/2/11 9:12
Bleed the M/C separately.
Remove the pipe & place a thumb over it for the return stroke of the pedal to prevent ingestion of air. Once the M/C is free of air you can bleed the whole system with confidence.
