Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Datsun 200B??
Rainz
Posted on: 2007/3/15 1:10
I 200B Datsun wagon just come up for sale cheap near me. Just wondering if theres any good parts on them for the 1200 or not :)
Cheers
#2
Re: Datsun 200B??
shirley
Posted on: 2007/3/15 1:36
Well, yes and no. You could pull the entire engine and drive train out and put it in your 1200, but that is a very expensive and time consuming exercise. It would give you heaps more power and heaps larger fuel bill.
Maybe you could use the struts and brakes, I think the 200b would be a good upgrade but better confirm with the wise old chaps here first. Maybe the front seats, depending on their condition, and if you want to go that way. Mirrors may be good. Good luck
#4
Re: Datsun 200B??
Dodgeman
Posted on: 2007/3/15 2:45
Re: Datsun 200B??
PIGDOG
Posted on: 2007/3/15 3:43
you can use the engine and trans in a 1200, and you will probably want to also use the tras tunnel and clutch pedal/master cylinder assembly as well
you can use the front struts and brakes, just like doing a stanza conversion (use stanza or sunny lower arms and stuff) you just end up with better brakes and more suspention travel the L20b will give you a rather large boost in torque and a fair boost in power, they dont really use much fuel (i get 8 litres per 100km when im thrashing mine all the time)
#6
Re: Datsun 200B??
Rainz
Posted on: 2007/3/15 7:30
Whats an early model?
Its a 1980 model. Its great condition on the inside. Body is straight but lots of rust bubbling through. $500 or near offer
#7
Re: Datsun 200B??
Dodgeman
Posted on: 2007/3/15 9:00
Re: Datsun 200B??
WhiteSedan
Posted on: 2007/3/15 9:40
you can use the front struts and brakes, just like doing a stanza conversion (use stanza or sunny lower arms and stuff) you just end up with better brakes and more suspention travel But you have to remove the lower spring seat as its too large for the 1200 strut tower, you can use the 1200 lower spring seat or a stanza 120y or sunny seat. You can view topic.
