#1 210 Throttle Cable
AgentWright007 Posted on: 2007/4/24 16:17
Whilst cleaning the carbureator with the engine running (as advised by a mechanic friend) my poor Datto caught fire. Luckily, the only things damaged were a few wires (now repaired) and my throttle cable, which is now melted to itself. The dilema I am now faced with, is finding and/or fixing the throttle cable. So far all of the places i've checked with in Phoenix, AZ tell me that this item has be discontinued. A friend of mine has given me some standard throttle cable. Will this work? What are my options?
#2 Re: 210 Throttle Cable
Dodgeman Posted on: 2007/4/24 18:39
What method were you using to clean the carb?
Most use a spray can of carb cleaner, then bring the revs up to about 2,000, then spray into the throat of the carb.
The outside is cleaned with the engine off.
#3 Re: 210 Throttle Cable
AgentWright007 Posted on: 2007/4/24 21:03
That's what we did. The reason it caught fire was because the carb had a bad rubber seal that allowed fluid to leak to the outside. What I really need help on is the throttle cable.
#4 Re: 210 Throttle Cable
Gary_P Posted on: 2007/4/24 22:16
Have you tried the local u-pull-it wreckers?
I was scrounging parts for moving my battery into the trunk last Sunday. There was a '79 210 in the Foster U-Pull-It in Portland. Can't remember if the cable was there though...
#5 Re: 210 Throttle Cable
AgentWright007 Posted on: 2007/4/24 22:32
I called a few salvage yards including an all Nissan and Toyota yard and one that I got my rear end and passenger window from. No dice. Ive been trying to think of ways to fix the existing cable, or modifying the other peice of cable I have to make it work; but i'm not sure how. It sucks how a 20 dollar part can keep me from driving for a few days.
