#1 what is the track width of a 1200 diff
shirley Posted on: 2007/5/3 3:09
I'm Looking around for a strong diff for the 120y (I assume they are the same track as a 1200). So I'm just wondering what the track width is.Cheers
#2 Re: what is the track width of a 1200 diff
Dodgeman Posted on: 2007/5/3 3:19
The rear track of a stock Datsun 1200 is listed as being 1,245mm or 49"
#3 Re: what is the track width of a 1200 diff
shirley Posted on: 2007/5/3 22:52
Thanks so much. I've got a stanza diff for sale (on ebay for $1)and it's about 55". I was hoping a 1200 lover would take advantage of it . However it would need to be cut down for that.
#4 Re: what is the track width of a 1200 diff
Cameron_Datto Posted on: 2007/5/3 23:43
Be care not to confuse Wheel track with Diff width , a stanza diff is 1400mm from axle face to axle face . 100mm wider than a std 1200 diff
#5 Re: what is the track width of a 1200 diff
Cameron_Datto Posted on: 2007/5/3 23:49
Mazda b2600 diffs can be made to fit without shortening for the 120y ( depends on the wheel offset ) but they need the stud pattern changed ,, bit of a over kill for a N/a engine but they most likely come with a factory lsd .
#6 Re: what is the track width of a 1200 diff
shirley Posted on: 2007/5/4 0:10
Okay thanks for that Cam. I'd love an lsd. The 55" was face of hub to face of hub if you know what I mean. b2600 does that refer to a light truck that can carry 2600kg.?
#7 Re: what is the track width of a 1200 diff
dog160 Posted on: 2007/5/4 4:03
No, the 2600 refers to the engine size. ie 2600cc- 2.6litre.
#8 Re: what is the track width of a 1200 diff
beattie Posted on: 2007/5/4 4:23
But it is a light truck...well ute... Its a Bravo
