#1 what sway bar?
gx1200 Posted on: 2007/5/7 19:28
Hey there, just wanting to see what sway bars people are using (if any) on the rear of their 1200 sedans?
Any opinions would be appreciated
Cheers. Adam
#2 Re: what sway bar?
whoridas_girl Posted on: 2007/5/7 20:06
i was under the impression that a 120Y sway bar could be used or is that just for the ute?
#3 Re: what sway bar?
gx1200 Posted on: 2007/5/7 20:10
I dont know, just trying to find out what I can use or what is better for my 2 door sedan. I took it out to Mallala race way on Sunday and the rear was a bit "skatey"
Adam.
EDIT: that was my 500th post
#4 Re: what sway bar?
dats-me Posted on: 2007/5/7 20:11
120y's dont have rear sway bars. people do put 120 FRONT bars in 1200's though if thats what u mean?
#5 Re: what sway bar?
whoridas_girl Posted on: 2007/5/7 20:16
could be i dunno luke was saying we need to get a120Y sway bar so he could possibly mean the front
#6 Re: what sway bar?
pepper Posted on: 2007/5/7 20:21
he has stated at least twice that he wants info on 'rear' swaybar options
#7 Re: what sway bar?
ANGE Posted on: 2007/5/7 21:00
excuse my ignorance but if the rear was "skatey", wouldnt fitting a rear sway bar add to that problem as the rear would be more rigid?
or was the skateyness a result of the bodyroll?
#8 Re: what sway bar?
WhiteSedan Posted on: 2007/5/7 21:06
What sort of rear springs do you have adam, also what shocks?
#9 Re: what sway bar?
benny Posted on: 2007/5/7 21:39
In my opinion, 1200's need to be soft in the rear on the circuit. A good set of springs and no sway bar an you are good to go.
Also stiffen up the front. 20mm bar of a 120y is the goods.
However if you require a rear bar, I used to use an aftermarket "Selby" rear swaybar designated for a 120y wagon rear. 16mm from memory.
#10 Re: what sway bar?
wagon1200 Posted on: 2007/5/7 21:42
I was thinking about using a Gemini rear sway bar, whiteline even have a kit for a larger unit,
eg
whiteline
