Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Aftermarket Temperature sending unit.....Can it placed ...here?
Bluemax
Posted on: 2007/5/9 17:15
#2
Re: Aftermarket Temperature sending unit.....Can it be placed..here?
Dodgeman
Posted on: 2007/5/9 21:41
I can't see why not. It will be placed into the coolant flow at the hottest part, right where it belongs.
Depending on what you can buy, you might need an adapter, or reducing bush, but as long as the hole is a standard metric size & thread, it should be a doddle.
#3
Posted on: 2007/5/9 22:28
also make sure the thermo probe does not obstruct the passage way, the passage wa there is not that deep.
Maybe if you can just get the tip into the coolant area it would be good. You can view topic.
