Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
1200/180B brake/strut question
1200wag
Posted on: 2007/5/12 11:43
I'm sure this is already on the forum somewhere, but can anyone tell me if 180B struts/ lower arms will fit straight onto a 1200 ute or if 180B rotors and calipers will fit onto 1200 disc struts??? Cheers, Pete.
#2
Re: 1200/180B brake/strut question
PIGDOG
Posted on: 2007/5/12 11:49
180b control arms can fit somehow...havnt looked into it
but once the lower control arms are fitted, then the 180b struts will obviously go onto them you will just need to change the spring perch on the strut to a smaller one to fit in the 1200 strut tower, also need to use the 1200 strut tops you will also need the 180b tierods and outer tierod ends and i think you use the 180b radious rods you can make it work, just i havnt done it so cant tell you exactly what to do but 180b brakes wont fit onto 1200 struts
#3
1200wag
Posted on: 2007/5/12 14:14
Sweet. Thanks for your help. Reason I ask is I have a 180b i'm wrecking so I guess I will hang on to all the front suspension. Cheers, Pete.
#4
PIGDOG
Posted on: 2007/5/12 14:18
wouldnt feel like donating its half shafts(axles) to me for my ute would you
#5
1200wag
Posted on: 2007/5/12 14:34
All I want is the booster and front suspension. What ever else you want let me know. Running L18/4speed.
#6
matbighat
Posted on: 2007/5/12 15:10
i don't know if you can use 610 lower arms. i've always heard you need a10/b310 items
#7
PIGDOG
Posted on: 2007/5/12 17:19
ive heard of a few people using them, apparently they are longer
i was supposed to check the ones on my 120y(180b front end) and see the length difference id think you would need to enlarge the hole in the crossmember to use a bolt thick enough for the 180b arms You can view topic.
