#1 wat botl size are the door hinges??
crzy_1200_ute Posted on: 2007/5/13 11:31
hey guys
i have to drive an hr away to get door hinges and i need to no wat size the bolts are..
the door side are a 12 socket...
but wats the car side..
cheers
#2 Re: wat botl size are the door hinges??
ade Posted on: 2007/5/13 16:21
8mm ftom memory same as most engine bolts, go to a bolt shop
#3 Re: wat botl size are the door hinges??
crzy_1200_ute Posted on: 2007/5/13 19:26
wtf..
i said im going to get hinges but i dnt wanan take a toolbox if i no wat size socket they are to take them off
#4 Re: wat botl size are the door hinges??
WhiteSedan Posted on: 2007/5/13 19:36
The bolt is a M8 (8mm) size bolt.
A 12mm socket will do the job. Someone may have replaced them at some time and you may need a 13mm socket.
