Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
a15 gains
doyle
Posted on: 2007/6/12 23:02
hey i own a dato 1200 ute built by trp...its got a 5speed race box,full shaved body, worked a15 which is board with webbers,exsuast system,custom diff plus heaps more......a HEAP of money spent on this ute and i just need info on mods i ken do to the motor eg turbo?....
#2
Re: a15 gains
Trav
Posted on: 2007/6/12 23:28
<------------------- The search button and tech section is over there Doyle. Learn to be friends with it!!!
#3
Re: a15 gains
Mildman
Posted on: 2007/6/13 0:31
I woiuld approach turbocharging with a little bit of caution - if the engine has been that heavily work it probably has a very high compression ratio - which will make it difficult to turbocharge.
You might be better off fitting a modern twin cam turbo motor if the worked A15 isn't fast enough for you. Like a CA18 or SR20.... Depends really what you are after - it this a race car, drag car, show car, street car....and why do you want it to go faster - is there a goal or target in mind?
#5
Re: a15 gains
doyle
Posted on: 2007/6/13 1:35
yea i considered the ca18 conversion but the amount of work i would assume is high.......but then again its ben retunneled for the new box so maybe not...wot bout fuel injection or sumthing along those lines
#6
Re: a15 gains
doyle
Posted on: 2007/6/13 1:37
ill take sum today.....i only got the ute from syd 3 weeks ago
#7
Re: a15 gains
PIGDOG
Posted on: 2007/6/13 1:39
if its already got webers that are in good tune, making up fuel injection for it and keeping it NA wont give you much of a power boost
#8
Re: a15 gains
doyle
Posted on: 2007/6/13 1:45
Yea well they r 32/36 webbs.....4 into 1 extractors...lightend flywheel...2.5inch system....k&n air.... boarded etc etc but i want more boogy
#9
Re: a15 gains
Posted on: 2007/6/13 2:13
Doyle, are you revving it high enough? With those parts, if done right it should be running sweet at over 4,000 rpm. Rev her up to at least 6,000 and keep her revved high for maximum performance
#10
Re: a15 gains
Mildman
Posted on: 2007/6/13 2:27
Have you had the ute on a dyno to see the sort of torque curve you have at the moment?
Also knowing the compression ratio would be good. You can view topic.
