#1 seam weld or not
perthute Posted on: 2007/6/14 21:35
i have put a a ca18 non turbo in a 12oo ute some people are saying im a retard for not seam welding
wat do you think ????
#2 Re: seam weld or not
Coops Posted on: 2007/6/14 22:31
Wouldn't worry about it for a N/A CA18, or for that matter, just about any street car.
If you were intending to spend a lot of time at the track / strip with a high HP motor, getting heaps of grip (resulting in high chassis stresses), I'd say go for it.
But then again.... If you have a bare shell, a MIG & heaps of spare time........
#3 Re: seam weld or not
converted Posted on: 2007/6/16 2:16
only if its gonna be used for rallying
#4 Re: seam weld or not
Mildman Posted on: 2007/6/16 2:20
by converted on 2007/6/16 12:16:59
Or if it has as much power as Andrew's coupe....
#5 Re: seam weld or not
dat383 Posted on: 2007/6/17 9:21
i run a 383 chev in mine and it is not seam welded.
it gets lots of twist,but no cracking or structural problems.
#6 Re: seam weld or not
Mildman Posted on: 2007/6/21 13:08
Is that for drag strip only dat383?
I remember ca18det_man saying his body was cracking under the power and cornering G forces....that's why he needed to seem weld - but that is an out and out circuit car.
#7 Re: seam weld or not
dat383 Posted on: 2007/6/21 13:56
yeah,my car is drag only,so i guess it could be a different story for the circuit racers.
although my comment was more towards the power figures coming out of a non turbo ca18 and the need to seam weld his car.
