Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
CA into 1200 wiring???
WARDY
Posted on: 2007/6/19 14:30
Hey everyone just wondering what the go is with wiring the CA18DET into the 1200?? has any one got any info to share?
Or is there a wiring kit available? Thanks for the help Wardy
#2
Re: CA into 1200 wiring???
Mildman
Posted on: 2007/6/19 14:44
There is a main EFI harness - that you can take from the stock harness, you also need a couple of things from the 'engine' harness - like knock sensor and oil pressure switch and a couple of relays to run the fuel pump.
I ended up with a custom loom from a company in NSW - have the name at work.... Got a few pics of it of page 2 & 3 of my "CA18DET Prep" pages. (like the one below)
#3
BUNDY351
Posted on: 2007/6/19 22:47
You could also send ya loom to Kev Rowley in Brisbane and he will convert it for ya for a few hundred bucks. Still doing it last time I checked.
You running standard computer or aftermarket??
#4
WARDY
Posted on: 2007/6/19 22:48
Thanks mate...as i am not the best electrician in the world i was thinkin that a custom made loom would be the go.. If u get a chance ta get that number thatd be great thanks man
#5
WARDY
Posted on: 2007/6/19 22:53
Im thinkin aftermarket... just for future mods down the track.. that way its already done..
#6
Mildman
Posted on: 2007/6/20 0:43
Quick Fit Motorsport
(02) 9476-2877 http://www.quickfitmotorsport.com.au/ Contact name: Steve (not there on Wednesdays). Doubt it will help but you can say that Ben from Melbourne recommended you.... They do all sorts of custom looms I believe.
#8
short-coupe
Posted on: 2007/6/20 9:26
you can get a haltech that plugs straight in using the factory loom, maybe start standard, then upgrade later, i was surprised how good a chipped ecu is. last time i heard Kev charges $400 for a plug in loom
#9
WARDY
Posted on: 2007/6/20 9:41
Yeah i have been thinkin of that option too.. microtech also do the same thing.
Does anyone kno how hard it is ta wire in the map sensor so no AFM is required?? What is the go with Chipped ECU's?? is it to match the mods u have done or are they all the same? I dont kno much bout the elecrics side of them
#10
Laney
Posted on: 2007/6/20 9:47
Since were on the subject im going to run a microtech loom with my mt8 whats involved in getting rid of the afm? can i just do it cause i have computer and loom . . what do i need to do?????? thanks
