#1 CA 18 det parts
aca18t Posted on: 2007/6/20 7:24
one E-bay T-70 turbo T-3 flange split pulse exhaust new never used suit applications up to approximately 280 rwkw paid $480 sell for $380
40mm external wastegate brand new never used paid $150 sell $120
Ca 18 det factory manifold with T-3 flange welded on $50
These parts were to be for a throw together engine for some cheap fun which never eventuated.
Ca 18det Tomei flywheel 4kg mate this is that light and thin it is actually blue on the back from heat used $200
Ca18det Billet steel flywheel 5.5kg lighter than stock never used only been fitted with ring gear $250
Ca 18det sintered Bronze clutch and pressure plate used $100
Ca18det stock cams and pulleys $40
Ca18det stock headgasket new unused $40
CA18det factory airflow meter $ 50
Ca18det factory auto computer $ 50
CA18det S13 5 speed gaerbox $350.
Many more CA bits just ask e-mail me for pics of turbo, stock rods pistons valve springs lifters coil packs injectors etc By the way all prices are negotable if you didn't already know.
Nick. 0409255322.
#2 Re: CA 18 det parts
hcope86 Posted on: 2007/6/20 7:31
HKS cam(s) as in a pair??
Are you sure they are 8.5mm lift? (this is max lift you can safly use ons tock springs)
If so consider them solddddddd!
PM me some payment details and ill sort it asap
Regards,
Hayden
#3 Re: CA 18 det parts
aca18t Posted on: 2007/6/20 7:53
yes a pair that is right the max lift for stock setup finally a man who knows his stuff
, I have a set of tomei 270 10.5mm solids in my motor.
Nick.
#4 Re: CA 18 det parts
hcope86 Posted on: 2007/6/20 9:14
ah the procams, i was looking at a set of those but i have already had my head done with the standard springs at the time, and i want to atleast start the motor before i pull the head off again hahaha
im so indecisive at times.
Well ill take them then, send me some payment details and ill get it organised asap.
Also, how are the cams with that much lift, are they still fairly driveable on the street, or the profile too wild for cruising?
cheers
#5 Re: CA 18 det parts
aca18t Posted on: 2007/6/20 11:32
which ones are you talking about because mine has a Trust T67 turbo for it so driveability is in the eye of the beholder don't you reckon. it is all relative big cams headwork big turbo = arp studs forged rods big valve springs for BIG REVS.
Nick.
#6 Re: CA 18 det parts
aca18t Posted on: 2007/6/20 12:38
anyone enquiring about parts pls ring me instead of e-mailing .
Nick.
#7 Re: CA 18 det parts
short-coupe Posted on: 2007/6/20 13:17
hoping for full boost when? 5000 or 6000rpm?
#8 Re: CA 18 det parts
hcope86 Posted on: 2007/6/20 14:59
yeah nice setup. Im running a gt3076r with a custom modified .48 rear housing that GCG built for me. Forged bottom end, arp studs, cometic mls gasket, but as for head work, im running standard bar a port and polish and oversized vales. This is why i want the cams hehe, i have though about going completely nuts on the head, but im worried that i will push the powerband too far up the rev range and make the car too uncomfortable for the street, well for me anyway!!!
Anyway how do you want to do this? is bank deposit ok? if so shoot me a PM with you details plz and ill organize the payment. Thanks mate!
#9 Re: CA 18 det parts
hcope86 Posted on: 2007/6/20 15:04
Alternativly, post up your number that i can ring you on and if greystanes isnt too far from me (nthn beaches - manly) i might come pick them up.
Cheers,
Hayden
#10 Re: CA 18 det parts
aca18t Posted on: 2007/6/21 3:26
people ring me on 0409255322.
Nick.
