Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
good deal ???? ca18det
perthute
Posted on: 2007/8/6 15:41
I will have a manual ca18det engine, gbox, ecu, etc etc left over from a sr20 swap i will be doing in about a weeks time. Engine has done 208***kms which i have done only 4000kms. Original owner was a 35 year old lady and car was stock with only a BOV on it. Coil packs have just been swapped over.
Engine sometimes idles at different revs e.g. 700-1400 but returns to normal once accel is pressed. Gearbox tends to pull when downshifting into 2nd but i have had no probs driving it. Would be good for parts or for upgrading a non turbo sil/180 $1000 ono anyone interested in engine can pm me to have a look and i can take you for a drive while its still in he now wants $600 for it not to bad of a deal wat do you guys think could be making it rev up and down ???????????? im looking at buying this, its not mine :)
#2
Re: good deal ???? ca18det
dazzasute
Posted on: 2007/8/6 19:44
Hey I saw that ad!
Sounds like a good deal to me. If your going to do something serious with the engine you'll want to rebuild it anyway or at least get it checked out, no matter what the previous owner says. You get to drive it before you buy it which is a LOT more than most people get before they get the engine. $600 sounds like a really good buy. I paid $800 for mine, and while it was the friend of a friend it apparently runs, but will need a rebuild pretty soon, although mine came with a t28bb turbo. Make sure you get as much as you can from him, from tail shaft to intercooler.
#3
perthute
Posted on: 2007/8/6 20:12
thanks dude yea i will wanna drive it for a lil while, befor a rebuild . i hope the motor doesnt sell befor i can get out too it
#4
crzy_1200_ute
Posted on: 2007/8/6 21:28
i paid 1300 for mine.. and i got gearbox engine, all the wiring
most wreckers sell them for 2grand so its a great buy if its just the engine with no turbo then 600 sounds about right
#5
perthute
Posted on: 2007/8/6 23:36
its motor, turbo, box ,loom ,ecu , but high kms
#6
1000Coupe
Posted on: 2007/8/7 17:44
the uneven idle could be a few things, maybe sticky throttle body butterfly. give it a clean and some crc around the shaft and throttle cable, linkages.
maybe the O2 sensor faulty, disconnect it and see what happens, maybe the auto choke, disconnect that and see what happens. You can view topic.
