#1 Datsun 1200 wirring questions...
Demo Posted on: 2007/8/18 20:35
on the passendger side
there is a wite with red stripe wire is this the starter motor wire???
on driver side there are 3 green wires near fire wall?????
all the rest go to battery im guessing???
And where is the original wirring for wiper motor???
im sure ill have more on this 1???
but that will get me started
any help
thanks
#2 Re: Datsun 1200 wirring questions...
old_school Posted on: 2007/8/18 20:46
3 green wires go to the horn relay. I think.
Wires for wiper start at drivers side of engine bay near fire wall. A lead about 1m long runs along firewall to the wiper motor and plugs into loom at right side of engine bay.
White with red??? Cant recal would have to get manual out for this one.
Have you got a wire diagram of a 1200. Makes things heaps easier.
If no you may find one on the net or a manual at the local library. Or maybe someone in your area could organise photocopy.
Let me know how you go or if need copy of wire diagram.
#3 Re: Datsun 1200 wirring questions...
Demo Posted on: 2007/8/19 20:24
still stuck on wirring
i might post pics and label the wires i dontno
#4 Re: Datsun 1200 wirring questions...
WhiteSedan Posted on: 2007/8/19 20:29
What country?
#5 Re: Datsun 1200 wirring questions...
Demo Posted on: 2007/8/19 20:33
Australia 70 model
#6 Re: Datsun 1200 wirring questions...
tappet Posted on: 2007/8/20 7:38
the white red is for ur alternator...
the three wires, 2 greens and one black is for ur horn relay.. the black should be earthed
the starter motor wire will be closer to the firewall end and is black/red i think..
the wipermotor has it's own plug that is also nearest the firewall on the engine loom....
#7 Re: Datsun 1200 wirring questions...
Demo Posted on: 2007/8/20 11:31
white with red stripe=alternator=passenger strut
3wires,2green,1black=horn relay=close to firewall and driver strut
?????=horn
Starter motor=black/red=close to firewall
is this correct so far???
anything else or more details???
cheers
#8 Re: Datsun 1200 wirring questions...
Mawler1 Posted on: 2007/8/25 2:38
don't know about an early 120Y or 1200 wiring loom
but on a late (March '77) 120Y aussie 120Y the wiper motor wires and anti deseling switch (yellow wire) are in a 1 metre lead closest to the firewall - closest to the two rectangular pugs under the dashboard
then the headlight relay is on a short lead nearby
the horn wires are near the plugs for the indcators and parklights/under bumper indicators
I think they are green - 120Y's have 2 horn wires as they have 2 horns
