#1 Bolt patterns for Weber, Dellorto and Solex/Mikuni
clyons8 Posted on: 2007/8/30 11:10
Are the bolt patterns (of the 40mm sidedraught carb) the same between the Weber/dellorto vs Solex/Mikuni?
#2 Re: Bolt patterns for Weber, Dellorto and Solex/Mikuni
PIGDOG Posted on: 2007/8/30 11:27
they are the same
#3 Re: Bolt patterns for Weber, Dellorto and Solex/Mikuni
clyons8 Posted on: 2007/8/30 12:21
I've got a round port twin manifold that fits perfect on the head. As soon as I align the carbs the throttle axle on either carby touch putting one or the other out by about 3.5mm.
So if I bolted one on and then went to bolt the second on, the hole allignment would be out by 3.5mm
What shall I do to get it to fit?
#4 Re: Bolt patterns for Weber, Dellorto and Solex/Mikuni
WhiteSedan Posted on: 2007/8/30 12:23
Chris, what carbs are you using? You could trim a bit off the axle and get a thinner nut, got a pic?
#5 Re: Bolt patterns for Weber, Dellorto and Solex/Mikuni
clyons8 Posted on: 2007/8/30 12:26
Yeah, got a pic just trying to get it up. Hang on......
#6 Re: Bolt patterns for Weber, Dellorto and Solex/Mikuni
Tyrie Posted on: 2007/8/30 12:26
my solexes did that, just filed a few mm off each threaded end of the throttles til they fit.
#7 Re: Bolt patterns for Weber, Dellorto and Solex/Mikuni
PIGDOG Posted on: 2007/8/30 12:27
so im guessing your using the standard linkages on some solex carbys? and its the link doover between the 2 carbys that is hitting
you will need to trim them down as they werent designed for the carbys being spaced closer together
but if thats not wats happening just ignore what i said
#8 Re: Bolt patterns for Weber, Dellorto and Solex/Mikuni
clyons8 Posted on: 2007/8/30 12:30
Yeah thats what I was about to do. So this means that the manifold will do the same for all other makes??
#9 Re: Bolt patterns for Weber, Dellorto and Solex/Mikuni
clyons8 Posted on: 2007/8/30 12:41
Okay here are the images i took a while ago. Sorry guys I don't know how to do the link thing. Worry not just a few extra clicks ; )
Looking at the image they look out by about 5mm, hmmm
http://www.flickr.com/photos/12431623@N06/
EDIT: I have Solexs....
#10 Re: Bolt patterns for Weber, Dellorto and Solex/Mikuni
WhiteSedan Posted on: 2007/8/30 12:42
