#1 A14
Buket_of_water Posted on: 2007/9/26 11:39
i have decided im going to drop my a14 into my ute
anyway. is water pump, alternator, fuel pump etc interchangeable?
its the older style a12 right now.
also. on the a12gx head. what angle are the carbies on?
thanks for your time
chris
#2 Re: A14
1200rallycar Posted on: 2007/9/26 11:41
water pump and alternator interchangable
but fuel pump has a different length arm to the cam shaft
#3 Re: A14
Buket_of_water Posted on: 2007/9/26 11:44
cool i might look at a eletric fuel pump or if im lucky the block still has the pump on it (kinda put it in the coner and forgot about it)
#4 Re: A14
1200rallycar Posted on: 2007/9/26 11:49
have you got a gx setup?
#5 Re: A14
Buket_of_water Posted on: 2007/9/26 11:52
not that i no of. i just want the angle for a project with will no be completed haha
oooo is the dizzy interchangable too?
#6 Re: A14
1200rallycar Posted on: 2007/9/26 11:55
dizzy is
some manifolds for the gx's are diffrent
hard manifolds to get hold of too
possible that a12gx manifold is straight out
a14gx is angled upwards maybe 20 degrees
(could be wrong though)
