#1 Datsun 1600 SSS twin SU carbs
Pillay Posted on: 2007/12/24 10:46
Hi Out there can anyone confirm if the 1600 SSS carbs will fit the 1200 GX cylinder head.
Regards
Pillay
#2 Re: Datsun 1600 SSS twin SU carbs
Dodgeman Posted on: 2007/12/24 10:54
No they won't. Firstly, you need a manifpld to mount them on & secondly, the linkage that joins them together is quite different, both in length & construction.
The 1600SSS carbs will actually bolt onto the GX manifold, but that's pretty much where it ends.
#3 Re: Datsun 1600 SSS twin SU carbs
Pillay Posted on: 2007/12/24 11:04
Hi Thanks you just saved me a deal of effort and time.
#4 Re: Datsun 1600 SSS twin SU carbs
Posted on: 2007/12/24 20:50
that said as well, i am using l18 su carbs on my a series manifold and the l series linkage can be modified to wory with the a series manifold if you are using lseries su's on them.
sometimes its worth the effort if you have an a series manifold as any sus are getting harder to find in good condition. also depends what price they are going for.
