Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Bench testing Tach & gauges
edp
Posted on: 2007/12/24 19:08
Being that I haven't had to check one in 20 plus years I cant remember how to do this.
Do you ground it out to check continuity or something like that? I recall it's similar to bench testing a fuel tank sending unit but other then that i'm drawing a blank. Thanks, Evan
#2
Re: Bench testing Tach & gauges
Posted on: 2007/12/24 19:24
The factory Datsun 1200 tachometer is unlike most others. It uses an induction signal, and is not directly connected to the distributor points/coil wire. I have no idea how you would bench test it. For a wiring diagram, see Wiki - Wiring Tachometer
For the dash gauges, 12V in the right place, along with selective grounding would work. For a wiring diagram, see Wiki - Wiring Gauges You can view topic.
