Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
whistleing noise
nismo
Posted on: 2008/1/5 6:17
Hi everyone,
When I drive my 120y, I can here a slight whistleing noise, it's not all that loud and it does it in all gears including neutral, and it doesn't matter if the clutch is in or out either. I jacked up the rear today and started it up in first gear and let the clutch out to get enough speed for the wheels to spin so I could hear the noise. It sounds like it's coming from the end of the gearbox where the tailshaft goes into. Has anyone struck this before. Cheers
#2
Re: whistleing noise
frankthedolphintrainer
Posted on: 2008/1/5 6:26
is it a sound like a fan spinning or is it like a old kettle boiling, if its like a kettle boiling maybe check for oil leaks aswell
#3
beattie
Posted on: 2008/1/5 6:53
check your oil level! The A12 box in the thou started screaming when i rean it dry
Topped it up and its all good now
#4
agro4
Posted on: 2008/1/5 10:20
mines doing the same thing and gets worse as the car revs, kinda sounds like its coming from alternator
#6
nismo
Posted on: 2008/1/5 12:02
I forgot to say that the gearbox has been fully reconditioned not all that long ago, I also put in a new clutch plate at the same time.
I will check the oil level and go from there. But the noise doesn't get louder as you rev it or anything. Thanks guys for your comments You can view topic.
