#1 bluebird struts
bluedat Posted on: 2008/1/30 2:26
hey i was just wondering if bluebird struts would go into a 1200 ute with worries, like scrubbish or anything like that. cheers
#2 Re: bluebird struts
A14force Posted on: 2008/1/30 3:48
You have to swap the top hat, and use a B310 steering arm, with an adapter ring to spigot them together. You may also need to "massage" the inside of the strut tower due to the larger coil diameter. Whle your at it, you should go for the longer "HB310" ball joints to improve the camber.
