#1 what the, no one can tell me engine rebuild spec's
82vanette Posted on: 2008/2/16 5:07
rebuilding my a12 need to know engine spec's
#2 Re: what the, no one can tell me engine rebuild spec's
A14force Posted on: 2008/2/16 5:42
Stuff like crank journal tolerances, and bore limits can be found in most workshop manuals. I have one, but it's not here.
#3 Re: what the, no one can tell me engine rebuild spec's
82vanette Posted on: 2008/2/16 14:44
Cylinder head bolts . . . . . . . . . . . . . . . . . . . . . . . . . 74 Nm
Connecting rod nuts . . . . . . . . . . . . . . . . . . . . . . . . 37 Nm
Flywheel bolts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 88 Nm
Main bearing cap bolts . . . . . . . . . . . . . . . . . . . . . . 59 Nm
Camshaft sprocket ......................... 47 Nm
Camshaft locating plate . . . . . . . . . . . . . . . . . . . . . . 8 Nm
Sump bolts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Nm
Oil strainer bolts ........................... 14 Nm
Crankshaft pulley bolt . . . . . . . . . . . . . . . . . . . . . 196 Nm
Timing chain cover bolts . . . . . . . . . . . . . . . . . . . . . 7 Nm
Rocker pedestal bolts . . . . . . . . . . . . . . . . . . . . . . . 25 Nm
Valve rocker adjusting nut . . . . . . . . . . . . . . . . . . . 22 Nm
Sumpplug . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 29 Nm
#4 Re: what the, no one can tell me engine rebuild spec's
82vanette Posted on: 2008/2/16 15:15
#5 Re: what the, no one can tell me engine rebuild spec's
82vanette Posted on: 2008/2/16 15:17
not if your quicker with a knife
#6 Re: what the, no one can tell me engine rebuild spec's
clyons8 Posted on: 2008/2/16 23:53
