Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
CA18det turbo help
GIDZ
Posted on: 2008/2/26 8:44
I am in the process of putting back the turbo. I have figured out all the oil lines but am having problems with the water lines.
Can someone tell me where does the water line that comes out from the turbo bolt onto the engine. This is the line which if facing you when you are looking at the turbo from the passenger side of the car. All help will be appreciated Cheers Gideon
#2
Re: CA18det turbo help
frankthedolphintrainer
Posted on: 2008/2/26 9:05
it goes around and under the exhaust manifold it connects up to a small box only 2cm x 2cm which is under the further most exhaust port looking from the front of the car if that makes sense
