#1 are a12 and a15 flywheels the same?
woody Posted on: 2008/6/3 11:13
hi guys im just wondering if a12 and a15 flywheels are the same?
cheers guys, kurt
#2 Re: are a12 and a15 flywheels the same?
billyberch Posted on: 2008/6/3 11:17
hi im not sure if there the same but they both fit each other because i have put a a12 flywhell on my a15
#3 Re: are a12 and a15 flywheels the same?
Dodgeman Posted on: 2008/6/3 11:17
They are interchangable but not identical.
The larger the engine the heavier the flywheel.
#4 Re: are a12 and a15 flywheels the same?
woody Posted on: 2008/6/3 11:20
thanks for that guys
cheers kurt
#5 Re: are a12 and a15 flywheels the same?
datto1000wagon Posted on: 2008/6/3 13:00
dodgeman i am going to have to argue with you on this i have a flywheel off my a14 it is the standard one but is far lighter then a standard a12 one its at 9 kgs standard a12 is about 11-12 kgs
#6 Re: are a12 and a15 flywheels the same?
clyons8 Posted on: 2008/6/3 13:25
It's not an A10 flywheel is it?
#7 Re: are a12 and a15 flywheels the same?
1200GXman Posted on: 2008/6/3 14:16
As far as I remember with previous posts about the same subject, one of the members had A12,A14 and I think also a A15 flywheels. He weight them and I cannot confirm the weights but was as Dodgeman said.The bigger cc engines had heavier flywheels.
Very strange that your A14 one is lighter than a A12 one. Not really suppose to be according to posts that I read in the past.
Are you sure it has'nt been "played" with by a previous owner?
#8 Re: are a12 and a15 flywheels the same?
ddgonzal Posted on: 2008/6/3 17:04
In addition to the weight difference, flywheels from 1974 up have larger bolt holes:
1967-1973: 3/8 inch bolts
1974-2007: 10 mm bolts
See A Engine Redesign
#9 Re: are a12 and a15 flywheels the same?
dattodude Posted on: 2008/6/3 21:24
I've also heard of potential mismatches of flywheel and starter motor and backing plates with the A15.
Sorry I don't have anymore details on these facts.
#10 Re: are a12 and a15 flywheels the same?
datto1000wagon Posted on: 2008/6/3 21:49
yes i am sure it hasnt been played with it has though a very large valley runing around it on the motor side i will take a photo of it and post it oh and i think the a14 may have been out of a forklift or something similar
