#1 1200 COUPE 4 sale still
showandgo1200 Posted on: 2001/6/15 1:49
1969- Regular trophy winner yet driven everywhere,driven 2500 miles since rebuild, detailed A15 worked, balanced, 10:1 compression,crow cam,new pistons, double valve springs,larger valves,
ported head,match ported manifold with twin 42mm webers, electronic ignition, custom made ceramic coated tuned length extractors,stainless exhaust system, engine is painted with lots of
chrome, revs to 8000rpm easily, adjustable coil over suspension with KONI shocks,larger sway bar,polished 5 speed gearbox with custom made billet gear knob, bigger disk brakes with brake
booster,stops on a 5 cent piece,6 gauge autometer dash (all in the cabin), wood steering wheel on a collapsable column. New carpet, hood lining,seats,door trims etc,hidden wiring,bare metal
resray 2 pak (blue), louvered GX bonnet,flared guards,no badges,excess holes removed from engine bay and body, battery removed to the boot,all new weather strips,three way immobiliser,all
work done by professionals,handles like a dream,all registered and legal,perfect streeter or as weekend car,always turns heads. Perfect if you are thinking of a rebuild as this will be much
cheaper and it already has all of the good parts.
PRICE $10 000 (will not go any lower)
Will seperate if you are buying most of the parts.
Can view photos at the car shows album created by dattodude. Thanks dattodude.
