Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
need help installing a weber 32/36 onto a 120y
jez_120y
Posted on: 2008/6/23 10:39
just bought a 120y and ive tracked down a weber 32/36 carby. problem is im not entirely sure how to get the thing on...can any one help?
#2
Re: need help installing a weber 32/36 onto a 120y
baldy
Posted on: 2008/6/23 10:55
With mine I just bought an adapter plate and bolted it straight on used throttle parts off original carbie easy as that
#3
LittleFireyOne
Posted on: 2008/6/24 10:08
That's what I did but the cable used to slip out all the time and besides pissing me off it happened at some dangerous times. My solution was to buy a redline throttle cable ( the $50 one) that takes a ball type connection at one end and modified it to suit another rocker cover which I had a bracket welded on to. I don't have any pics of it on this other pc of mine so I'll get some later
#4
beattie
Posted on: 2008/6/24 10:44
all i do to stop it slipping its use the original carbys bracket to hold the outer cable inplace. Everything from the A series carb is interchangeable except for the internal workings etc pretty much!
#5
baldy
Posted on: 2008/6/24 11:08
thats right chris I had no problems useing the old carbie's cable and throttle parts cable has never sliped out
#6
nismo
Posted on: 2008/6/24 11:31
The only problem with my weber was where to hook the accelereator return spring to.
#7
benny825
Posted on: 2008/6/24 13:34
what about re-building these carbs? anyone got any tips? I have 3 of them but they've all been sitting in the shed for years!
And how do they rate performance wise compared to su's?
#8
beattie
Posted on: 2008/6/24 13:38
Yeh i had that problem too nismo. I just got a 10c spring from a auto shop and hooked it onto the air cleaner(ramflo). You could muck around and make a fancy mount but meh.
Compared to SU... I would say SUs would flow better. Depends on your setup really, headwork etc. I run a 32/36 because i was given one.
#9
LittleFireyOne
Posted on: 2008/6/26 7:26
Yeah some people hate webers but I like them, they're simple as piss and it's only when you've broken it that you should start to worry or get annoyed
