#1 fitted a 120y struts into datsun 1200 But Problem
littlefats Posted on: 2008/6/26 13:39
ive recently fitted 120y struts into my datsun 1200 with the disc brakes. it stops fine but when i completly turn the steering wheel, suddenly the brakes dont work and must pump to regain the brakes
can anybody explain the problem
i just changed the struts only.....
cheers
#2 Re: fitted a 120y struts into datsun 1200 But Problem
WhiteSedan Posted on: 2008/6/26 13:45
Sedan or coupe?
If you get pressure and keep your foot on the pedal then turn full lock does the pedal move?
Sounds like your flexible lines might be twisting and causing it to block fluid.
#3 Re: fitted a 120y struts into datsun 1200 But Problem
littlefats Posted on: 2008/6/26 13:55
its a sedan, and when i go after i turn the steering, weird noisers are heard until i pump the brakes, it stays hard if i leave my foot on the petal
cheers buddy
#4 Re: fitted a 120y struts into datsun 1200 But Problem
littlefats Posted on: 2008/6/26 13:57
how could i fix this problem
cheers buddy
#5 Re: fitted a 120y struts into datsun 1200 But Problem
old_school Posted on: 2008/6/26 14:01
Did you put the struts in the correct way? The caliper should be at the front.
Did you use the 120y flexable lines - They may be different length to 1200 ones?
#6 Re: fitted a 120y struts into datsun 1200 But Problem
WhiteSedan Posted on: 2008/6/26 14:11
Definitely sounds like the flexible lines, when I used the 120y struts I used the 120y lines, the 1200 sedan lines would be too short as they are only flexible to the strut, then hard line from strut to wheel cylinder.
If you did use the 120y lines then I suggest unbolting the caliper and see if it wants to spin and untwist the flexible line if you get what I mean.
#7 Re: fitted a 120y struts into datsun 1200 But Problem
Gary_P Posted on: 2008/6/26 16:11
Check to see that the caliper is not hitting the body work at full lock. If the caliper hits it might be pushing in the piston the pulls the outer pad inward. This would then require the piston be pumped back out before the brakes would work.
#8 Re: fitted a 120y struts into datsun 1200 But Problem
lukeADE Posted on: 2008/6/26 21:33
I run 120y struts in my car, and I have the caliper at the back like they were originally. No hitting on anything, no problems. I do have a coupe though... is there any difference between coupe and sedan?
I did use the 120y flexible lines for mine.
#9 Re: fitted a 120y struts into datsun 1200 But Problem
Posted on: 2008/6/26 23:01
if it was a drum front end did you change the master cyl to a twin one?
#10 Re: fitted a 120y struts into datsun 1200 But Problem
WhiteSedan Posted on: 2008/6/27 7:41
It wont be that, I ran the single sedan master with my 120y brakes and Im still running a larger single master with my R30 brakes.
