Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
brake issues! Need a part!
candyflippa
Posted on: 2008/8/5 10:34
Hi there. I need a part for the front right drum of my 1200 wagon. It is a little cam thing that adjusts the drum (not sure what it's called). The drum had seized and when i undid the adjusters it snapped. I called a brake joint today and they reckon you can't buy the part anymore. Can any1 tell me if this is true or does any1 have this part floating about? Would be much appreciatede as it will be ready for a roady as soon as this is done!
Cheers Ed
#2
Re: brake issues! Need a part!
ROConnor
Posted on: 2008/8/5 10:37
Should be a member with some front drums floting about that hav bin replaced by disck's?
Ask datsandy, hes wrecking a sedan ATM.
#3
DatsAndy
Posted on: 2008/8/5 10:38
Are sedan drums the same ? We have a drum brake front end for a sedan. A pic would be good if possible just to be sure we are on the same channel.
#4
ROConnor
Posted on: 2008/8/5 10:42
There should be 2 17mm bolt head's on the rear of the drum top and bottom that hav a snail shell shaped thing on the inside of the drumm that the breakpads hav a tab that rest's on them, not sure if they can be removed entirely or if you need the whole backing plate?
#5
candyflippa
Posted on: 2008/8/5 10:45
Hmm um I would say they are the same. I don't have any photos. It's a cam looking thing about the size of a 50 cent piece and it has a stud coming out of it with thread to adjust the drum. Hope thats some help
#6
ANGE
Posted on: 2008/8/5 10:47
i have a pair of 76 model ute drum front struts that you can have for free if you come and pick them up.
they were working in my ute before i upgraded to discs. good shoes and wheel bearings etc. im in the western suburbs
#7
candyflippa
Posted on: 2008/8/5 10:55
that would be mad. Could you give me some contact details? Cheers Ed
#8
baldy
Posted on: 2008/8/5 12:22
I still have the complete drum brakes I took out of my sedan you can have any thing you want off them if you like
#9
revhead001
Posted on: 2008/8/5 12:39
Do people still use drum fronts? What a world!
