#1 sedan springs
wiXeS Posted on: 2008/8/21 11:06
are sedan springs the same as ute springs
#2 Re: sedan springs
ddgonzal Posted on: 2008/8/21 17:12
No, ute springs are heavier duty.
#3 Re: sedan springs
Dodgeman Posted on: 2008/8/22 1:51
Each different car had its own springstack & each, with the possible exception of 2 door & 4 door sedans, was different
#4 Re: sedan springs
ddgonzal Posted on: 2008/8/22 3:11
Coupe & 2-dr sedan use the same leaf spring assembly (at least in North America): Part Number 55020-H1000
#5 Re: sedan springs
PIGDOG Posted on: 2008/8/22 9:27
they all have the same length main spring from eye to eye so are interchangable. you will need longer U bolts if running the ute leaves with the load leaf still in the pack though as it adds an extra half inch to the thickness of the spring pack
#6 Re: sedan springs
rock1200 Posted on: 2008/8/22 9:48
Does any one have any ute springs for sale?
Pref SA
#7 Re: sedan springs
1200GXman Posted on: 2008/8/22 9:59
Can't one then put ute springs in the back of a sedan that is used for track days,etc?
