Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
It Worked!!!!! A14 MPFI
Retal052
Posted on: 2008/8/24 13:22
Hey Guys.
Got me YZF-R6 MPFI setup working today!!! The bike throttle bodies work well and deliver more than enuf fuel to power the A14/wA15 head. Having a small issue with fuel consumption. Chewed through $10 fuel in less than 20KMs. Think it has something to do with the fact Im missing the air temp sensor from the haltech. I have the coolant temp sensor as the air temp sensor it reports the air temp to be 40 degrees. anyways it works guys!!
#2
Re: It Worked!!!!! A14 MPFI
PIGDOG
Posted on: 2008/8/24 13:53
so whens it going to get tuned properly?
and how is it tuned at the moment? TPS vs RPM? or is it still trying to use the map sensor?
#3
Retal052
Posted on: 2008/8/24 14:33
Its all connected...except the air temp sensor and coolant temp sensor....TPS/Manifold pressure and RPM.
I think it uses all....TPS/pressure and RPM.
#4
cheater_5
Posted on: 2008/8/24 21:49
pics...... this thread needs pics! and a video lol
#5
frankthedolphintrainer
Posted on: 2008/8/24 22:04
40 degrees sounds about right for an engine bay
#6
PIGDOG
Posted on: 2008/8/25 3:34
there are pics and a video in the other thread
#7
Retal052
Posted on: 2008/8/26 11:05
there are pics and a video in the other thread Cheers dude. looks pretty much same fitted properly. Induction noise is MAAAAADD. very loud without airfilters
#8
dazza1200
Posted on: 2008/8/27 13:54
if its that rich you will kill the motor by washing all the oil off the cyl walls and lining up the ring end gaps.
fix it before you drive it any more you have been warned! dazza
#9
Retal052
Posted on: 2008/8/27 14:14
yer not driving it til the end of the week till I get the air temp sensor
