#1 J15 Engine swap!
Bandit_blues Posted on: 2008/11/18 9:45
I was looking for an A14 engine on the net and i found a really cheap one then i asked the guy about it and then he told me that is a J15 engine! Is this a good engine? Where can i find more specs about it? The transmition is the same of the A series?
#2 Re: J15 Engine swap!
ROConnor Posted on: 2008/11/18 9:55
J's are older, han only three main's, shared intake port's. would maybe be a little more powerfull than a stock a12 but not much I wouldent think?? these motors were rplace buy the A series and nissan did so for a reason..
#3 Re: J15 Engine swap!
Bandit_blues Posted on: 2008/11/18 9:58
You`re right, i never thought about it!
#4 Re: J15 Engine swap!
ROConnor Posted on: 2008/11/18 10:02
No wories mate. I would look for an A series, dont think a J's worth investing in?. good luck!
#5 Re: J15 Engine swap!
dazza1200 Posted on: 2008/11/18 10:42
forklift engine!
#6 Re: J15 Engine swap!
datski620 Posted on: 2008/11/24 8:33
this engine also came in the datsun 620 ute's but then got replaced by the L16. Apparently the J15 had a good torque range but was a work horse and slow
#7 Re: J15 Engine swap!
DattoFrog Posted on: 2008/11/25 4:27
Datsun 1500 1 tonners had them. NO top-end but pull a brick dunny over. Great motor if you are building a mud buggy or a tractor.
#8 Re: J15 Engine swap!
TUF-110 Posted on: 2008/11/25 5:03
DONT DO IT!!! youll deface the poor car
#9 Re: J15 Engine swap!
spenc Posted on: 2008/11/25 21:09
the idea of an engine conversion is to make it faster not slower
#10 Re: J15 Engine swap!
D Posted on: 2008/11/25 23:13
Might as well use an L series for weight as the J is cast iron top to bottom
