Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
datsun1000 brake upgrade
steveo
Posted on: 2008/11/19 12:23
as some of you might know i'm in the middle of a racecar build, my 1000 is in the process of getting the works, and i need some suggestions on a brake package. I'm looking for a pair of vented disks is there any availabe out there that fit on the 1000?
Someone mentioned HQ one-tonner brakes up front, what hub needs to be used for such a set-up? do i need a custom hub for bigger brake package? vented rotor or otherwise? Also is a brake booster needed? or just a twin master cylinder?
#2
Re: datsun1000 brake upgrade
datto1000wagon
Posted on: 2008/11/19 12:51
i mentioned the hq front end if you are going with a full cage so you may aswell go that bit further and make up custom mount for the hq frontend and it gets rid of that damn leaf spring allowing you 2 drop the motor lower by cutting the crossmember up plus big brakes...
edit heres a pic of the hq front end i belive if you are going big power with a fairly heavy motor then use the hq stuff but for a hot a series screw around with a vannette front end
#3
steveo
Posted on: 2008/11/19 13:07
Do Vanette come with ventilated rotors?
#4
dattoman_1000
Posted on: 2008/11/19 14:27
Thats a Torana front not a HQ
Bit of overkill though very heavy front brake setup
#5
Dodgeman
Posted on: 2008/11/19 16:24
When you say Holden one ton, do you mean that's what they come off, or that's what they weigh?
I would imagine that for such a light car some dazzling brake performances could be obtained with something less weighty, .... something from an S13 or S14 perhaps?
#6
sven
Posted on: 2008/11/19 19:59
we've fitted the S13 silvia rotors, and made a custom plate to hold in some VN Commodore calipers... got a VS master cylinder to do the work... (its a work in progress)
#7
datto1000wagon
Posted on: 2008/11/19 23:21
LOL so they are but they are pretty much the same thing neil and yes they are heavy but i was thinking more towards not having to keep the front leaf and i only sugested it if you are going for lots of power and a heavy tall motor
#8
bert
Posted on: 2008/11/20 0:09
I'm constantly amazed at how many people fall into the idea that the povo transverse leaf set up on the 1000 series is no good!
Sure it's primitive,but once understood it can work a treat....and cheaply. The work involved in the fabrication(that actually works)of a new front end set up is complex and time consuming exercise and should only be attempted by people with the appropriate level of experiance along with a very healthy budget,added to all of this is the engineering required for legal road use,or alternatly for motor sport(CAMS) you cannot compete unless in a Sports Sedan class. Having done this exercise many years ago along with on going development at the time i can report that the effort did not come close to the ultimate results expected. As for the brakes,grab yourself some Hyundai Sonata rear rotors(ventalated)and shove them straight over the top of the 1000 hub(same stud pattern)which will sit inside the rotor centre,grub screw to the hub or leave "floating"your track will increase by the width of the thickness of the face of the rotor centre,which is good. If using 13" wheels you can get a laser caliper inside with a little grinder relief hanging off a fabricated bracket or if bigger diameter wheels a BMW caliper or Holden is a good choice. The old B10 was able to out stop every car it ever competed against with the above set up with laser calipers. It also used one of those horrible transverse leafs
#9
datto1000wagon
Posted on: 2008/11/20 0:32
if you had read all my posts then i wouldnt have to explain myself tenfold. bert what im saying is if you are going all out and using a high hp motor that is heavy and possibly tall then you would want to get that motor as low down as possible (lower centre of gravity means better handling) that could potentially mean having to cut up the crossmember (or sit next to the motor) so now you have the issue of the leaf spring so if you used the hq front end you get copius amounts of brakes and you can cut up the crossmember down fall of it is lots of homework and fabrication involved
BUT if you are going a small compact motor like the aseries then keep the leaf and opt for a lighter setup and that transverse leaf isnt such a bad thing go look under some late model corvettes i think you might be surprised as to what you see but it can be a pain in the ass if you want to hack that crossmember up
#10
bert
Posted on: 2008/11/20 1:14
I was'nt speciffically refering to your post Brent,and i did read it all and all the others along with all the others over the years but making a general comment on some folks attitude towards the humble"sideways leaf"
Until we know what Steve is aiming to achieve and in what class he would prefer to be competing in all comments on what he should or should'nt do remain hypothetical as i'm sure you know. The best any of us can do is report on personal experiances in the hope others don't make similar mistakes. As a matter of interest,my Sports Sedan with mid mounted L series all those years ago started with the transverse leaf and progressed to HR holden front end,but was never as efficient(geometry)as the original set up. I like to think i understand C.G.,Roll Centres,Weight transfer issues etc. quite well along with a very good knowledge of Vette's,i spose it come's with the grey hairs You can view topic.
