#1 twin webers cheap
akinaspeedstar Posted on: 2008/12/2 9:28
i have used genuine Weber down draft IDF carbs
condition: used, look like they have been kitted in the past few years. the butter flies open and close extremely smoothly
specs: 36mm throttles
price: $450
#2 Re: twin webers cheap
akinaspeedstar Posted on: 2008/12/4 4:16
no one?
#3 Re: twin webers cheap
steveo Posted on: 2008/12/4 5:17
what were they originally off? have they been jetted for a 1200?
#4 Re: twin webers cheap
akinaspeedstar Posted on: 2008/12/5 2:18
i couldnt tell you either im afrade. ive never actually used them.
best guess would be that they where off an alfa around the 1.8-2L mark....
#5 Re: twin webers cheap
D Posted on: 2008/12/5 4:37
The Idf are hard to find manifolds for the A series.
Usually common on Alfa Sud SOHC 1.6 only.
The 1.8 and twin cam boxers usually only came with fuel injection.
I had an old vw based porsche spider copy 15 years ago with the 1.8 and twin 40mm IDAs it was a rocket but everything shook and flexed terribly as it was poorly constructed and 20 years old then.
#6 Re: twin webers cheap
akinaspeedstar Posted on: 2008/12/5 10:41
this maybe true, how ever im sure there would be quite a few exhaust shops willing to make up a manifold to suit. weather it be a datsun or otherwise. should nearly be cheaper to make than extractors. then if your worried about heat, wrap them or have the manifold ceramic coated.
also thanks for the info, i really had no idea what these would have originally come from. i was taking a stab in the dark really :P but they seem to be in great condition
#7 Re: twin webers cheap
akinaspeedstar Posted on: 2008/12/8 0:24
buyyy meee
#8 Re: twin webers cheap
akinaspeedstar Posted on: 2008/12/11 9:47
bump, im slightly neg
#9 Re: twin webers cheap
akinaspeedstar Posted on: 2008/12/15 6:19
buy buy buy
#10 Re: twin webers cheap
akinaspeedstar Posted on: 2008/12/20 4:29
still got them!
