Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
oil cooler info please
picko
Posted on: 2008/12/16 11:11
just wondering if it is necessary to up grade the oil pump when putting a cooler on.
cheers
#2
Re: oil cooler info please
WhiteSedan
Posted on: 2008/12/16 11:31
Yes but Im not sure if you need higher volume or pressure, For my L16 I have a rebuilt 280zx oil pump which is meant to be higher volume to run with my cooler and remote filter block, not sure if that has higher pressure also.
#3
datman55
Posted on: 2008/12/16 12:24
It's a good idea to do it if you can, the extra volume & distance the oil must travel will put extra strain on the pump.
Do you know for sure that you need an oil cooler? I opted not to run a cooler on my car, and it turns out I don't need one. Oil temps never go above 100 degrees. ![]() You can view topic.
