#1 Brake Booster needed?
Mad-1200 Posted on: 2008/12/28 3:56
hey guys
just wondering if i do need a brake booster to run front bluebird disks and stock drums on the back? will just the stock master be ok, or will it be to hard to apply the brakes?
any help will be much appreciated
#2 Re: Brake Booster needed?
ROConnor Posted on: 2008/12/28 4:00
It will take more effort without a booster, but will be able to break just as hard.
Id get them all working and balance right( front to back) and then if it takes more effort then you can be botherd with look into a booster?
#3 Re: Brake Booster needed?
DatsAndy Posted on: 2008/12/28 4:16
Just run a twin reservoir master if you don't already have one. Boosters just make the pedal softer. Boosters are for Eunich's
#4 Re: Brake Booster needed?
ROConnor Posted on: 2008/12/28 4:23
"Eunich"... is that like unfamilia??
#5 Re: Brake Booster needed?
DatsAndy Posted on: 2008/12/28 4:24
Unless he got them chopped after the last pregnancy, then No
#6 Re: Brake Booster needed?
Mad-1200 Posted on: 2008/12/28 4:40
sweet as, saves me muckin around, thanks again
#7 Re: Brake Booster needed?
PIGDOG Posted on: 2008/12/28 8:47
Boosters are for Eunich's are they andy?
like to see someone make my car stop at any kinda decent rate without the booster connected
#8 Re: Brake Booster needed?
dazza1200 Posted on: 2008/12/29 4:53
boosters reduce pedal effort only
this helps prevent firewall flexing
i have seen cracked firewalls in the past
if you need 2 feet and to pull on the bottom of the steering wheel to stop then you def need a booster
the only thing you sacrifice by having one is space,and even then you could use a remote one
dazza
#9 Re: Brake Booster needed?
PIGDOG Posted on: 2008/12/29 8:26
2 feet and pulling on the steering wheel is about what i was doing on my one trip without a booster....not very fun
#10 Re: Brake Booster needed?
DatsAndy Posted on: 2008/12/29 8:40
Yeah boosters are for Eunichs regarding putting one in an average spec A series 1200. In other cases like your little beast PIGDOG and others they will make life easier . Back at ya HA HA
