Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
how do i convert my ute to a sr20det ?
datokid
Posted on: 2009/1/11 14:30
i was just wonderin how long a sr20det is and do i have to cut anything to fit the motor and a 5 speed gear box in my ute and is there any brakets i need for the convertion i know there is the cross member that suports the gear box but is there any thing else i need
thanks ps its a 1200
#3
Re: how do i convert my ute to a sr20det ?
nick_m
Posted on: 2009/1/11 19:50
If you need to ask those questions your best off going to maddat and spending the money and buying all the parts concerned, it will save you a whole lot of time and headaches
#4
bugsie
Posted on: 2009/1/11 20:06
i might be wrong but i think maddats kits
don't have to recess the fire wall now, i know u use to. and u will need to enlarge the trans tunnel for the sr20 gearbox, which u can also get from maddat and weld in yourself if u know hoe to weld. they sell pretty munch everything u need as far as fabrication goes anyway.
#5
hotrocket
Posted on: 2009/1/11 20:09
how long a peice of string,
depends if your doing a full restro or just fitting motor and box, if you have everything seating in front of you and have the no how shouldnt take to long at all, im fitting a CA18 in mine ive been collecting all the bits for the last year for ready to fit, BUT im still no were nere have it finish for other 9-12 mth's, im going to hole hog, ive been on it for 1 year now, $8500 to date its cost me so far and its still not painted ...........so goodluck and have a good hard look into it............cheers
#6
bugsie
Posted on: 2009/1/11 20:10
sss ute apparently is owned by the owner of maddat and from the pic it doesn't look like he recessed the fire wall....
#7
perthute
Posted on: 2009/1/11 21:38
yer fire wall stay's , check out sssute's build thread with all the parts ready to go did it in 9 days
your in perth, if ya want to drop over one day and check out my ute thats in the process of getting a sr20det put in it . it might give you a better idea of wats need'd but hears a quick run down , mines been off the road for 2+ years in that time its had a ca18de then ca18det then a second ca18det now a sr20det is about to go in , i have the maddat diff, brake booster ,crossmembers , mazda rx7 brakes with coilovers , fmic , 3inch zorst , fuel cell n surge tank , so pretty much every bit has to been swap'd for bigger stronger parts , some things people say you can get away with like the stock diff n only upgrage to stanza brakes , but i found the diff need's to be lsd or you'll paint black line's with out knowing it , and the stanza brakes where scary imo cheers
#8
sssute
Posted on: 2009/1/11 23:08
datokid, as all the guys above said its a time consuming and expensive conversion, but that said they go like a shower of ####!
The fire wall does not need to be recessed, but a larger tunnel is needed. The SR is a more envolved conversion over a CA, as the size of the engine is a far bit larger and makes all the tollerences much tighter. Radiator and cooler can be fitted behind the grill (just) and we have a custom rad. to suit. I dont want to scare you off, but i hate seeing unfinished projects for sale, but you would want to allow minimum of $10,000 for the conversion if you do most of the instilation yourself. Remember you must upgrade you brakes/suspention and diff with any high power conversion. We can supply everything needed for the job, or what ever you need. Cheers Scott www.maddat.com.au
#9
bert
So in a nutshell,lots of time,money and experiance.
And another daily while it all happens.
#10
DatsAndy
Posted on: 2009/1/11 23:24
Or buy one already done. Yes it takes the joy and heartache out of the job which go hand in hand really. You would get one for around 10k i reckon.
