#1 torque on flywheel bolts
baldy Posted on: 2009/2/3 10:26
can any body tell me the correct torque settings the flywheel bolts needs to be on an l series and are the bolts in the pressure plate mild steel or high tensile Had a l1600 in a buggy once the flywheel decided to come of a try to pass me
#2 Re: torque on flywheel bolts
Posted on: 2009/2/3 10:28
47ft lb the manual says im pretty sure... will check as that does not seem tight enough. more like 80lb on an aseries so l should be similar
#3 Re: torque on flywheel bolts
baldy Posted on: 2009/2/3 10:36
when I cracked the bolts off I had to use a pipe on the bar so I thought I should check. I recon about 80-90
#4 Re: torque on flywheel bolts
dattodude Posted on: 2009/2/3 10:39
110 foot pound on a ca18det
Sometimes crankshaft vibrations, missing harmonic balancer and 2nd hand bolts are the cause.
#5 Re: torque on flywheel bolts
Posted on: 2009/2/3 22:14
checked this morning, 76ft lb.
47 was for the head bolts.
