Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
SIZED PISTONS
hairylemon123
Posted on: 2009/4/15 1:15
Gday new to this site just bought my first dato and had head gaskeet crack and now sized pistions advice or help asap??????????????????????
#2
Re: SIZED PISTONS
Posted on: 2009/4/15 1:38
No need to fit over-sized pistons. If it is only a blown head gasket, prep the block face and head face well, and fit a new gasket.
#3
Re: SIZED PISTONS
hairylemon123
Posted on: 2009/4/15 3:42
i have skimeed the head all is good in that department complete new head gasket kit installed. but wont turn over im thinking that the pistons have seized and i dno how to free them ? or if im totaly stuffed?
#4
Re: SIZED PISTONS
Posted on: 2009/4/15 3:46
With transmission in nuetral, you should be able to turn the engine by hand either by:
* turning the fan, which is difficult or * by a wrench on the crankshaft bolt If it won't turn, remove the starter and try again. If it still won't turn, disassemble the engine and find out why.
#5
Re: SIZED PISTONS
hairylemon123
Posted on: 2009/4/15 4:28
hmmm ok ill give it a go thanks for your help !!! i have a feeeling im stuffed know anywere good to buy a twin cam ???
#6
Re: SIZED PISTONS
Posted on: 2009/4/15 5:37
yeah down at your local car delaer, but it comes with a rubbish car, not a datsun
#7
Re: SIZED PISTONS
clyons8
Posted on: 2009/4/15 5:58
Going on a little further from dd's advice, I always found it much easier to turn the engine over by hand by removing the spark plugs. That erradicates all the resistance (compression).
You really need to have a good look before you declare the engine seized. You'd need to give a bit more information to get a reasonable response. You can view topic.
