#1 CA18det help needed
Simmo999 Posted on: 2009/4/15 10:18
hey guys,
just wondering what size fuel lines most people are running? 5/16 or 3/8?
Cheers in advance
#2 Re: CA18det help needed
hotrocket Posted on: 2009/4/15 10:35
im using 8mm alloy on my ca conversion
#3 Re: CA18det help needed
old_school Posted on: 2009/4/15 11:05
Im using 5/16 on my coupe with a stock CA18DET. I have a Goss motorsport fuel pump and have had no issues with 5/16 fuel lines.
Unless you are going to be chasing huge Hp the 5/16 lines would be adequate.
Dont know where you are located but in WA Fuel lines under the car have to be steel bundy tube.
5/16 - 7.9 mm
3/8 - 9.52 mm
I used the original 1/4 line as purge to the charcoal canister
#4 Re: CA18det help needed
Mildman Posted on: 2009/4/15 11:32
5/16 feed, and the original 1200 fuel line as the return - pretty stock motor....yet to be tested.
Could find anywhere to buy 3/8 bundy tube in SE Melb!
But I think even 5/16 on a 044 Bosch pump will be double what I actually need.
#5 Re: CA18det help needed
matty Posted on: 2009/4/15 22:25
I'm using 5/16 without drama on a mildly modified CA putting out just over 160rwkw.
#6 Re: CA18det help needed
Simmo999 Posted on: 2009/4/16 10:43
cheers guys, also another thing with regards to fuel. Im thinkin about running a surge tank with a facet to supply the surge tank and a bosh 044 to supply the motor! is this sufficient?
#7 Re: CA18det help needed
dattodude Posted on: 2009/4/16 11:12
044 might be a big noisy. That's the biggest problem.
A small facet should be fine (edit: for a lift pump). 90% of your fuel will come from the return line under most conditions if the return line is correctly plumbed to the surge tank. STandard EFI diameter Bundy tube is fine. 3/8 is overkill on everything except a turbo rotary.
Hey Hotrocket, please check with engineer about the alloy fuel line when running EFI pressures.
I think I remember hearing it's not legal. I know it's easier to fit bend and fit though ..
#8 Re: CA18det help needed
matty Posted on: 2009/4/16 11:13
Sufficient for what mate?
Until you provide an idea of the power level you are chasing our answers will be nothing more than guesswork.
What I can tell you is that the Bosch 040 intank pump I am running in the factory mounting position of my R31 tank will comfortably support 180rwkw.
Hope this helps.
Matty
#9 Re: CA18det help needed
matty Posted on: 2009/4/16 11:25
For what it's worth 170rwkw is quite achievable on a standard motor with a 200SX T28, chipped ECU, exhaust and 18psi.
This figure obviously depends on the condition of the motor, quality of modifications and how happy the dyno is.
#10 Re: CA18det help needed
hotrocket Posted on: 2009/4/16 12:00
yep thanks dattdude checked out all good
