#1 200B struts
rotahead_dato Posted on: 2009/4/19 14:06
hi people..
i need a little info. i have been given a set of 200B front struts, no discs and calipers. at the moment i have a set of 13" rims on my ute and am wondering if i put the 200B struts in once i have purchased the discs and calipers will the rims still fit. At this time i have 120y struts in the ute.
thanks
#2 Re: 200B struts
LittleFireyOne Posted on: 2009/4/19 16:32
That depends on teh brake setup you're going to get for it. the landcruiser calliper combo fits in most 13's and the commodore calliper magna disc combo should do too, Ian's car runs that setup with 13's. Also, you got the hubs with it? cos that can make the decision for you if you had certain parts already.
#3 Re: 200B struts
hotrocket Posted on: 2009/4/19 21:41
i wouldnt use any of those combo's anything under 14", if anything id be going 15" low profile tyres,
have you ever seen landy or magna's using 13"!!!
keep the struts you have go s13 disc's/caliper's combo
#4 Re: 200B struts
pepper Posted on: 2009/4/19 22:52
i have used 13 inch wheels on 200b struts with 200b calipers before.
they just fit.
#5 Re: 200B struts
rotahead_dato Posted on: 2009/4/19 23:34
thanks heaps people.
the rims are super lites 13x7 and tyres are yokohams 215 50
littledarkone..i have the hubs, but the studs on the hub are a little short and im unable to bolt the rim onto it.
hotrocket.. are u sayin keep the 200b struts or the 120y struts.
i have just found maddat has the DIY coilover kits, thats the reason for all the fuss
thanks again
#6 Re: 200B struts
b310gx Posted on: 2009/4/20 0:23
While you have the chance, you can swap the wheel studs. Get some longer studs from a wreckers, from a Bluebird(910), & you can fit those to the hubs. You might have to cut a small notch in the studs, but I think you don't have to with the 200B hub. New rotors are available from RDA at $70 each, then you only have to find some calipers. There are 2 sizes for the 200B rotors, the early ones are 10 inch, the later ones are 9.75 inch. The difference is due to them using a common disc/caliper with the Stanza. This would make it easier to fit 13 inch wheels if you used the later combo, though I've had some 13 inch rims fit over the larger ones.
#7 Re: 200B struts
Posted on: 2009/4/20 0:50
i manage to get 13 inch rims on my 200b set up, but only 2 out of 8 choices have fit on. you can use stanza hubs and clipers on the 200b strutrs (girlocck type) and they clear all 13's i have ever tired
