Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Engine mounts
Aegis
Posted on: 2009/6/18 5:19
I really need to replace my engine mounts. I have destroyed my fan, punctured my radiator and now my alternator is chipping at my heater/radiator jose connector. I'm about to go source some mounts now.
Any one replace mounts before? What's invovled? Do I need any engine lifting gear? And has any one had trouble gettin mounts for an a14 in a b110?
#2
Re: Engine mounts
Posted on: 2009/6/18 5:29
just place a jack under pan. Use a block of wood to protect the pan. Lift the engine, slip new mounts in.
#3
Re: Engine mounts
racetech
Posted on: 2009/6/18 13:48
I replaced my mounts with a set of these http://www.race-tech.co.za/gallery/main.php?g2_itemId=593 as the old pair was starting to tear. In SA we have a Shop called Rubber Products and Mouldings, sure Aus must have a similar shop, ask them for Ford V6 Mountings, R180 Each (Aus +- $25), but worth every cent.
Just had to slot the holes in the engine mounts to accommodate the new mounting. The Datsun mount bolts are off center from each other. I can promise you, if you destroy these with a A series motor, you must be boosting.
#4
Re: Engine mounts
aidaniel
Posted on: 2009/6/19 8:38
try cortina mounts ... same bolts as 1200 ones but bigger cross section and they are round
as for fitting just get a mte to pull the engine to one side as you do them ... dont weight much lol
#5
Re: Engine mounts
dazza1200
Posted on: 2009/6/20 7:26
or you could even use datsun 1200 engine mounts!
#6
Re: Engine mounts
Aegis
Posted on: 2009/6/20 8:45
So what model of ford v6 or cortina is compatible. Have you guys done this before?
At my local "sprints" the told me they could get a set but they weren't sure if they were the right ones. So if I can get a better set that are definetly fit I'm gonna take that option.
#7
Re: Engine mounts
ROConnor
Posted on: 2009/6/20 8:49
Pretty sure they are the pomy caprie v6 ones verry similer if not the same as some of the rover v8 ones.
