#1 Lowering 1k nightmare
Wurzel Posted on: 2009/7/20 13:03
Like I previously stated, I need to lose the "baja" look on the 1k wagon for my RWC so, not wanting to spend too much or mess with the stock parts, I get a set of 2" lowering blocks, so the U-bolts arent long enough...drive around to bolt dealers, trailer makers, back to the bolt dealers who tell me they can make them...then get to the bolt dealers who make me wait 20 mins before telling me they cant, so a bit pissed off by now i go to an engineeer around the corner who tlels me the bolt dealers will make themn cheaper...i tell him nuh uh, he says leave it with me...2 days later he has the bolts for me...from the bolt dealers! They want $150 for them!!!
Thinking well Ive wasted days after these bolts now... they are hi tensile and at the end of my tether I go heres the cash gimmie the flippin bolts.
Go to put the blocks in today and THE BLOCKS DONT FIT!!!
It seems 1200 h145 mounts are different to 100 H145 mounts???
The blocks I have have these little locating lugs while the bracket locating lugs that mount the springs to my diff are much bigger:
So now im faced with the predicament. Get blocks custom made (unless anyone has them to suit they wanna part with but i already asked) knowing full well that it probably could have paid for spring re-set twice over by the time im finished...or count my losses and get them re-set and have a nice set of shiny new u bolts to throw through a certain bolt-shop window...
hmm what would a dattomaster do?
(dont say flip em)
#2 Re: Lowering 1k nightmare
beattie Posted on: 2009/7/20 13:08
Hey im a dattomaster?
Yes 1000 and 1200 mounts are different. I bought a 1200 kit and modded the blocks slightly. I think i had to drill out the hole to 16mm (from memory) and i found some washers that where a perfect fit for the pin! U bolts where too long and had to be trimmed as per usual. I knocked it over all in a arvo and i think the kit was like $70 new?
#3 Re: Lowering 1k nightmare
perthute Posted on: 2009/7/20 13:08
mod the blocks you have to fit like everyone elce ?
and if you buy your lowering blocks from say pedders they come with the bolts :)
#4 Re: Lowering 1k nightmare
Wurzel Posted on: 2009/7/20 13:21
Pedders coulnt help me when I went out there. the 1200 U bolts were different to the 1k anyhoo
yeh Beattie the drill/washer idea just might work, not sure how safe itd be ie: if that lug gets sheared by the washer, yr in trouble. Plus those lugs are tapered. but yeh were talking about blocks i guess...
Goddam im wishing id gone for the reset.
Still I might draw what would be ideal up and see how much to get it made, I mean surely its no biggie for someone with
a chunk of aluminium and a lathe...?
#5 Re: Lowering 1k nightmare
beattie Posted on: 2009/7/20 13:25
ive had my lowering blocks in for about 2 years like that? Its only a locator pin, I sheered both on my landcruiser and didnt realize till the next day cos the U bolts held the diff in place and i have a #OOPS#load more stress in the cruiser then a 1000 will ever have!
#6 Re: Lowering 1k nightmare
Dundee1000 Posted on: 2009/7/20 13:25
go sedan springs, that's a good start..
#7 Re: Lowering 1k nightmare
benny Posted on: 2009/7/20 13:27
Unless I have missed something, if the suspension was stock and unmodified, how can the vehicle be knocked back for a RWC? Whats the deal?
benny
#8 Re: Lowering 1k nightmare
Wurzel Posted on: 2009/7/20 13:29
1k sedan springs?
or will 1200 springs fit? (minus the mounts)
I get confused with what 1200/1k parts are interchangeable (as so obviously already demonstrated)
#9 Re: Lowering 1k nightmare
Wurzel Posted on: 2009/7/20 13:35
Yeh Beattie sounds good, itll hold till I go over the pits at least, I guess its up to Unfamilia wether its ok to drill his blocks tho :).
Benny, apparently the car cant have a rake, or so the guy doing the RWC is telling me. I could go to another guy but I have my reasons for staying with this guy ;)
#10 Re: Lowering 1k nightmare
beattie Posted on: 2009/7/20 13:38
They have rake like that because they are made to carry 500kg!
1000 sedan leaves will sit it a bit lower. I used to run sedan leaves and 2" lowering blocks in my 1000 wag and it sat pretty level.
(1) 2 3 »
