#1 Clutch Throwout Bearing Query
matty Posted on: 2009/8/6 12:46
Hi all
Do both 4 and 5 speed 60 series gearboxes use the same throwout bearing?
The box is behind an A12 if that is of any relevance.
Thanks Matt
#2 Re: Clutch Throwout Bearing Query
Dundee1000 Posted on: 2009/8/6 12:54
yes the bearings are the same,
some early A12's have the smaller diameter ones, and A10 ones are small..
#3 Re: Clutch Throwout Bearing Query
juniorjay Posted on: 2009/8/6 13:02
yes,, the length of the bearing carrier varies between 56 and 60 but bearing is the same
#4 Re: Clutch Throwout Bearing Query
matty Posted on: 2009/8/6 13:21
Thanks guys
#5 Re: Clutch Throwout Bearing Query
ddgonzal Posted on: 2009/8/7 2:59
I'm not convinced.
Same year 56 and 60 boxes use the same carrier. I think the difference is early engine vs older. They added a 3 mil engine plate at some point, and the carrier is 3 mm different. Datsun 1200 engines don't have a plated bolted to the rear of the engine.
Perhaps if you have the wrong carrier, just remove or add the engine plate to compensate?
