#1 Urgent required Alternator brackets
DattoFrog Posted on: 2009/8/13 3:06
Need Urgent!
A set of alternator brackets for a CA20E.
A 80amp alternator that I can fit on the 1200. New would be good.
A pair of lower balljoints datsun 1000 New prefered but GC used will be ok.
All of this is required urgently. Would rather give my money to someone here than a outsider.
#2 Re: Urgent required Alternator brackets
short-coupe Posted on: 2009/8/13 4:04
i have a couple CA18 alternators, what side do you want, as i have a fwd and rwd model, i'll check tha amps for you when i get home.
#3 Re: Urgent required Alternator brackets
DattoFrog Posted on: 2009/8/13 13:50
FWD Just need the brackets that fix them to the block. Do you know where I find the engine number on the CA20? I can't find it anywhere!
I need a 50-80amp to suit the 1200 must be able to hook up to external regulator. The ones off the CA20 would have internal regs and I dont feel much like stuffing around with the wiring to get them to work. But it isn't out of the question!
