Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
ca18de deck height and other info
D
Posted on: 2009/8/25 14:39
Just wondering if anyone knows the deck height of the ca18de or det?
also rod length and pisont compression heights? regards, dave
#2
Re: ca18de deck height and other info
A14force
Posted on: 2009/8/26 8:52
rod length is the same as a14/15. I'd have to measure the crown height tommorrow if I remember. you know they have a kick arse dome aye?
#3
dazza1200
Posted on: 2009/8/26 11:58
rod length 133 +/- 0.05mm
piston pin hole 19.987 - 19.999 pin 19.989 - 20.001mm deck height 204.75 - 204.85mm pin height ? all from genuine nissan manual (DET)
#4
D
Posted on: 2009/8/26 15:31
Thanks guys
so rod stroke ratio with 83.6mm stock crank is 1.591 piston comp height must be 30mm like the ca20? You can view topic.
